Differential Fluid Change
#171
I bought my Almasol from Rick's.
http://www.ricks2k.com/products/le1605.php
I think most of the Amsoil users choose Severe Gear 75W-90 for the diff.
#172
^ Correcto. That is what i used last week for my diff change.
Stuff is pretty thick, leave it out in the sun while you lay out tools and jack the car up to get it a little bit less viscous.
#173
Looking forward to some great results.
#174
Hmmm...So should I get the 75W-90 or the 75-110? I live in San Diego, CA
What do most s2k users from Cali use?
http://www.amsoil.com/a/synthetic-gear-oil
#175
S2K-lester, I think it's a no-brainer to go with the 75W-110 if the weight is available ... even if you lived in a cooler climate.
I am bent on trying Chevron's Delo gear oils and neither their conventional nor their synthetic is available in 75W-110 so I'm stuck deciding between 78W-90 or 75W-140.
Same for my back-up choice of Lubromoly: 75W-90 or 75W-140.
I may well be using the Amsoil gear oils 2-3 years from now ... and I would definitely use the 75W-110 in my AP2.
#177
is it better to use 75W-90 or 75W-110 in a really hot climate like my country (Saudi Arabia)?
and which brand do you think is the best? having in mind my car is boosted (if it makes any difference)
#178
in Israel we use a lot for a few years Redline 75w90 on drifting&tracking Miatas - so far no problems whatsoever.
but in SA temps are easily 10 degr higher than here....
(for gearbox we use Redline's MT90)
#179
buzz944, as temps and horsepower/torque go up, your weight/viscosity should also ... it's just a matter of degree. I think the 75W-110 is a no brainer there as well. I'm not sure I'd go the next step with an 85W-140 without a UOA telling me the thinner fluids were lacking.
Hard to know what brands are available there. Maybe use Amsoil Severe Gear or Red Line Oil Shockproof? The Shockproof has a TON of molybdenum disulphide in it ... not sure of its effects on the limited-slip diff.
Croc, Interesting to hear that you use Red Line Oil MT-90 in your gear box as it is significantly thicker than OEM spec ... and you're not much warmer than the southern third of North America. I'd mix Red Line Oil MT-90 and MTL and see if you can't get an easier shifting action ... maybe 80/20, 70/30, etc ... until you find the best balance.
Or do the same with Amsoil MTG and MTF which are the Amsoil equivalents to the 2 Red Ljne Oil fluids.
One pretty firm rule when mixing is to stay with the same brand so the additive package works more harmoniously. A little additive clash isn't likely to do damage ... but protection can be compromised over extended drains.
Update on my situation: 1 case of Chevron Delo 80W-90 is on its way to me!
I'll be using this in my AP2's diff for about 10,000 miles then I'll drain and to a UOA. Not sure what we'll find out about the fluid with the fluid in use merely 10K.
http://www.google.com/imgres?imgurl=http:/...iw=1024&bih=621
We'll see ...
We'll see ...
#180
