Differential Fluid Change
Old 03-16-2009, 08:04 PM
  #101
Squeezer's Avatar
Originally Posted by Eri_S2k,Mar 16 2009, 09:51 PM
Do you really need to change the washers on tranny and diff bolts???
most people here will tell you yes. however my washers have been torqued enough that i can't get them off the bolt anymore, i just leave them on there instead of trying to dremel the washers off. oil isn't as viscous as water. i don't have any leak problems.
Old 03-17-2009, 07:29 AM
  #102
Banned
2007 Zx-10's Avatar
^ bad idea
replace the crush washers every second or third change or it WILL start to leak slowly, trust me
I'd like to know the best place to get these washers...Hard Top Guy?
Old 03-17-2009, 08:18 AM
  #103
Jsmply's Avatar
Originally Posted by 2007 Zx-10,Mar 17 2009, 10:29 AM
^ bad idea
Yes, hardtopguy (Jeff) is the best place to buy anything OEM for our car!
Old 03-17-2009, 08:38 AM
  #104
Sobe_Death's Avatar
The parts guy at the dealer here just hands me like 3 or 4 when I ask for them. At least for the oil pan. The diff washers had to be ordered but they are so cheap you would be a fool not to get them
Old 03-17-2009, 08:41 AM
  #105
shotiable's Avatar
i asked for them at the dealership and they just gave it to me for free. free is a better price than $2+shipping not to knock on htg
Old 03-17-2009, 08:45 AM
  #106
Banned
2007 Zx-10's Avatar
stealerships are good for something after all
Old 04-23-2009, 12:38 PM
  #107
slimjim43's Avatar
Originally Posted by 2007 Zx-10,Mar 17 2009, 03:29 PM
^ bad idea
I agree.
I always reused washer for the oil, transmission and diff.
At 10K I changed diff. fluid with mobile 1, reused washer, @ 20K changed diff. with LE607, reused washer. After a while around 40K, I noticed a rattle sound when changing gear at high rpm. I thought maybe something was loose. So, recently at 60K I changed diff. with LE607 and replaced washer with a new one. Now, when changing gear at high rpm, no rattle sound at all. The diff. feels a lot more confident.
I try to search and see any other people had this problem, but couldn't find anything.
Now after reading 2007 Zx-10 comment, I think the fluid was leaking over time causing rattling sound when shifting at high rpm.
I would suggest replacing a new washer for the diff at the least.
Old 04-24-2009, 06:03 PM
  #108
az3ar's Avatar
To all please make sure you car is leveled when doing this. Otherwise you well end up filling the diff with the wrong amount of fluid. The car needs to be lifted from the front and the back this goes for the tranny as well.
Old 05-15-2009, 01:26 PM
  #109
thomsbrain's Avatar
Thanks for this DIY. I was able to change my own diff oil by following it. It came out black and stinky after 20,000 miles. Although I noticed the new Mobil 1 kinda smelled, too.
Anyway, anyone doing this should get one of those pumps with two hoses rather than the screw-on quart-bottle pumps, because gear oil bottles are too tall for the standard screw-on pumps to reach the bottom and get all the oil. I had to cut the top off my bottle half-way through the pumping process to get enough. In the process I dropped the hose into the oil, making it too slippery to stay on the pump... (insert cursing here). I managed to get it filled, but I tossed the pump and will get the other kind next time.
Old 05-18-2009, 09:24 PM
  #110
golfreak12's Avatar
You can find the orange pump pictured at Wal-mart in the automotive section. It was like $7 or $8.
Quick Reply: Differential Fluid Change
