differential blown~!
Sorry i just answered my own question. I just read Shocks DIY - https://www.s2ki.com/forums/index.php?showt...&#entry12226079
this is something i shoud leave to my mechanic to do. I Just dont have the correct tools.
Originally Posted by boxmetogo,Jan 9 2011, 02:42 PM
this DIY looks easy enough.
https://www.s2ki.com/forums/index.php?showt...&#entry16215953
I built the replacement rear for that DIY
With trade of you old damaged rear I send you a reconditioned rear ready to go for less than you can rebild your self.
I also helped shock with that build as well
If you chose to rebuild your self you can call me for instructions or advice. Good luck
Originally Posted by chris_barry,Jan 8 2011, 07:13 PM
Fit a Miata NB model crownwheel and pinion into your housing. I've found they are stronger than the Honda equivalent gears and bolt straight in.
Originally Posted by INTJ,Jan 9 2011, 04:20 PM
Really? This is a huge solution. Has this been posted in detail somewhere and I missed it?
Nothing against Puddy - I hear nothing but rave reviews about his work - but if you're running stock power and not beating on the car (racing, etc), then a stock replacement diff will be just fine for you.
Originally Posted by S2KPUDDYDAD,Jan 10 2011, 04:30 AM
That is why I build a stock reconditioned rear for just a few bucks more than some used rear. If you trade in the blown rear it ends up being about the same price as used
