Differential
Old 10-20-2008, 01:20 PM
  #21
street_ruler's Avatar
ok, i guess....if you cant deal with pumping a little oil maybe you shouldnt be doing this work.
i guess i dont really care.
Old 10-20-2008, 02:08 PM
  #22
Neutered Sputniks's Avatar
It's not about making the pumping easier, yo. The easiest way is to use as large a hose as you can fit in the fill hole - empty the quart in 5 mins tops. However, warming the oil would allow it to better flush out the grit (warm oil flows better...)
Old 10-21-2008, 06:01 AM
  #23
not it wont wash out the grit any better...the grit is high in the casing and gears right now. you need more volume. but eitherway. if it comes out it comes out/
Old 10-21-2008, 10:50 AM
  #24
05TurboS2k's Avatar
flush and run.....
random rocks/sand get crushed and exploaded into fine powder fairly easily.... little bits of steel however are another story, draing plug will get those.
Stilll no matter how positive you look at this situation bearings nor gears appreciate this.
boofer
11-02-2014 11:40 AM
Daygo S2k
06-05-2009 10:36 AM
HS2K007
04-12-2009 05:02 PM
amongmany
11-16-2003 12:11 AM
Gernby
04-11-2003 10:02 AM
Quick Reply: Differential
