Differences in brake fluid
Old 02-27-2012, 11:35 AM
macdaddies911's Avatar
Default Differences in brake fluid
Called dealership today for "Honda Heavy Duty Brake Fluid" Dot 3
The guy in Parts Dept said that there is only one type of "Honda Brake Fluid". I recall it has to be HEAVY DUTY BRAKE FLUID. Anyone have some insight on this. I don't want to put the wrong brake fluid in my clutch reservoir.
Old 02-27-2012, 12:02 PM
Bump
Old 02-27-2012, 12:10 PM
zeroptzero's Avatar
Received 3,765 Likes on 2,656 Posts
There is only one fluid sold over the counter at Honda that I've seen. Don't get hung up on the name it doesn't mean much, just like trying to find Honda SAE90 diff fluid, it doesn't exist.
I prefer to use Ford Heavy Duty DOT3 Fluid though. I use the Prestone version of Heavy Duty Ford DOT3 synthetic fluid, sold pretty much everywhere I think.
Old 02-27-2012, 12:12 PM
ftpsk8's Avatar
There is only one type of OEM brake fluid that I know of...
Old 02-27-2012, 12:16 PM
ok thanks guys
Old 02-27-2012, 12:23 PM
good enough?
http://www.amazon.com/Prestone-AS400...0377726&sr=1-1
Old 02-27-2012, 01:39 PM
s2000ellier's Avatar
Originally Posted by macdaddies911
That is what I use, its dirt cheap at Walmart. I drain and clean my MC/CMC every other oil change with it too.
Old 02-27-2012, 01:46 PM
zeroptzero's Avatar
That is good too, the one I use is in that line of products but it is for the Ford Heavy Duty spec, I don't see it in that web listing, but that one you listed is pretty decent too. I also use the Wilwood 570 fluid, it is in that web listing.
Old 02-27-2012, 03:18 PM
dwight's Avatar
I don't know if there are two types of fluids, but there are two types of labels. This website lists the part number as 08798-9008. I've ordered that same part number from Majestic Honda and got brake without without "heavy duty" on the label.
Old 02-27-2012, 03:24 PM
redlineracing's Avatar
I like Prestone DOT4 fluid.Has a higher boiling point.
\rlr
carolina
Quick Reply: Differences in brake fluid
