diff. question
Originally Posted by tekstar,Jun 25 2007, 02:08 PM
retorque your axle hub nuts to 220 lb/ft
or try shifting into first a bit slower/smoother
Don't mean to offend you, but make sure you depress the clutch completely
Try pushing the clutch down twice before putting it in gear.
Once in a while my car does the same, you can feel the resistance is greater when it's about to do that, so I ease it in... ahem...
I would say change out the tranny fluid, but with 800 miles I wouldn't
Have you been flogging the car and NOT following the break in procedure?
You might require a adjustment, I believe it's the clutch rod. But I think you should leave that to the very end (I would get Honda to look at it first)
My diff was "thumping" because it broke a tooth off the pinion gear. Minimal metal particles in the fluid when I checked it.
The tooth broke cleanly off and was sitting in the diff.
Originally Posted by iDomN8U,Jun 25 2007, 05:47 PM
2007 is torqued properly from the factory...
Boostaholic
04-09-2007 05:12 PM
