Diff Fluid Reccomendations-100k on
Old 12-12-2012, 08:20 AM
  #31
rrounds's Avatar
Originally Posted by FISH22
So 75w140 wouldn't be too thick for our diffs? I've used LE607 and LE1605 through most of my S2000 ownership. When my 06 was new, LE actually quieted down the diff quite a bit. I'm curious about this Amsoil severe gear stuff. Any huge differences between their 75w110 and 75w140?
A 75/140 would be fine in the S, Mobil 1 75w/140 has a pour point of -48c
I used to mix Mobil Delvac 75/90 and 80/140 in a 50/50 mix in my over the road truck and when I retired I had about 1 1/2 gal left so I use it in my S and any other vehicle(my bike to) that takes a GL5 lube. Some very good lube.
ROD
Old 12-12-2012, 08:36 AM
  #32
FISH22's Avatar
ROD
Old 12-12-2012, 01:47 PM
  #33
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
Amsoil 75w140 has a much lower temp pour point than LE1605 (SAE110), so it would be perfectly fine.
Old 12-12-2012, 02:30 PM
  #34
c32b's Avatar
It's not too thick. Combined with shear over time, the 140 would be my pick. Not too sure about thicker as I had an oil which was a 140 but almost 30% higher viscosity than the already thicker than OEM spec 140 I have now and felt the car slightly sluggish
Old 12-13-2012, 12:32 PM
  #35
SpitfireS's Avatar
There are two channels in the diff housing's casting.
One below the pinion shaft and one above.
They both connect the area between the 2 pinion bearings with the area where the Torsen (and most of the oil) is.
As far as I understand oil is thrown from the top of the ring into that top channel and returns via the lower one, IOW there is some oil flow.
Driving forwards....
Also, IIRC, the oil reaches the middle of the pinion, when stationairy.
That level will drop a bit when you drive as oil will stick to the ring and stay in the Torsen unit.
Still, I think the contact patch is at least partly submerged in oil, even when you're driving.
The pinion head itself will pick up oil too as the lowest part of it is always submerged.
Sixth.Gear
09-13-2010 04:54 AM
hypforlife32
03-02-2010 05:14 AM
C4SxM5
05-13-2006 03:10 PM
Jaydem
10-10-2005 04:36 PM
Quick Reply: Diff Fluid Reccomendations-100k on
