Diff fluid from Honda question
Old 05-29-2011, 01:17 PM
rugsr's Avatar
Mobil 1 what
What weight?
75w90?
Old 05-29-2011, 04:52 PM
rumberobueno's Avatar
Thanks JFUSION for your reply.
The manual says:
Hypoid gear oil
API classification GL5 or GL6,
Viscosity: SAE 90
Is the viscosity of the 80w90 SAE 80 or SAE 90 ?
I think it's SAE 90 according to some searches I did.
It does say on the bottle that this oil is for differential. It also says that it's GL5 and if I'm correct that it's SAE 90 then it should follow all the requirements specified in the manual.
Old 05-29-2011, 05:57 PM
dc2-2-ap1's Avatar
Originally Posted by rugsr
Mobil 1 whatWhat weight?75w90?
yes get mobil 1 75-90 gear oil.
Old 05-29-2011, 06:30 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
The manual says:
Hypoid gear oil
Viscosity: SAE 90
There arent too many SAE90 fluids out there, LE was one of the only manufacturers that I seen making it and definitely not any over the counter fluids. The funny part is that Honda spec'd SAE90 fluid but they never produced such a fluid.
An 80w90 fluid will satisfy the requirements of SAE90, it will flow better at lower temps but still protect well at higher temps, being GL-5 or 6 is good.
Now let me throw a wrench into the discussion. When the Honda S2000 was first engineered the SAE90 spec was in place, then a few years later the classification of fluids was changed and they put 110 in the previous range of SAE90. Thus today's 110 is closer to the SAE90 viscosity that was in place when the s2k was developed as of the year 1999. The 75w90 and 80w90 fluids you get today are on the thinner spec range of the previous (old) SAE90 spec, they are still in that range but it is on the lower end of the spec. Today's 110 fluid is more in the middle to high end of the old SAE90 spec range. LE now offers a 110 fluid, and I was running Amsoil's 75w110 fluid. That's not to say that there is anything wrong with the other fluids but I just think running a fluid like 75w110 is a better match to the old SAE90 spec. I hope that I haven't confused things more than needed here.
Old 05-29-2011, 07:10 PM
robrob's Avatar
This is what Puddy Mod Racing said to use on my rebuilt 1.5+ diff with the OS Giken LSD:
Break in,
Use 8 to 10 oz of Amsoil SAE 250 in the rear and a good quality GL-5 Hypoid 75/110 gear oil in the rear. Use this oil in the rear for 500 miles then drain.
Use 8 to 10 oz of Amsoil SAE 250 in the rear along with Amsoil synthetic severe Gear 75/110 gear oil every 6K miles.
When you receive the rear, fill it with about 22oz of 75/110. There is 8oz of Amsoil SAE 250 in the rear already. This mix should quiet the LSD and gears pretty good and provide added shock protection. Be sure not to over fill the rear, fill the rear until the oil starts to come back out of the fill hole. Replace the fill bolt once the oil slows to a light trickle
More Break in:
Drive the car like a civilized human for 300 miles, after 300 miles the rear is fully broke in and “normal” driving can begin.
You can use the Red Line to top off the diif when you get it if that is what you have on hand. 75/90 75/140 Red line will do.
As to [race car] break in just be sure to get the rear up to operating temp before hammering on it also you should do at least a few heat cycles since the gears are new. A heat cycle is bringing the rear up to operating temp (about 15miles) then letting it cool back down to ambient temp, about 12 hours.
Ben seems to like a high viscosity Amsoil blend.
Old 05-29-2011, 07:53 PM
rugsr's Avatar
Someone please school me but what does GL and LE stand for
Will it say this right on the bottle?
Old 05-29-2011, 09:13 PM
rrounds's Avatar
This is for GL
http://www.finalube.com/reference_ma...Categories.htm
and LE is a manufacturer
http://www.le-international.com/content.aspx?id=17
ROD
Old 05-30-2011, 01:55 PM
Thanks a lot JFUSION for this explanation. I read about this before but I didn't understand it. You made it very clear.
Next time I chose the diff fluid I'll go with 75w110.
Should I be good then to run with the current fluid for 15K miles as specified by the manual ?
Old 05-30-2011, 07:21 PM
zeroptzero's Avatar
You could run the recommended amount if you like. I'd run it about 7-10k miles max. I do mine once a year, I don't drive anywhere near that many miles in one year so I just do it yearly. I also time it with a tranny fluid swap and do both of them while the car is up in the air and levelled on jacks.
Old 05-30-2011, 07:33 PM
rugsr's Avatar
Thanks guys
I'll be calling around looking for 75w110
Jbragguk
06-16-2012 11:32 AM
chef-j
07-15-2010 10:35 AM
bupton
02-19-2008 02:39 PM
rahula
03-19-2005 11:24 PM
s2k_9000rpm
06-14-2003 03:55 AM
Quick Reply: Diff fluid from Honda question
