Diff Fluid for an 04
OK, so I have read all the horror stories about getting the wrong fluid in the diff, and figured out that I should change the fluid and I probably need the Mobil 1 75W-90.
Is there any reason that an 04 should need a different diff fluid than older models? There were some diff changes for 04 ...
Thanks.
Thanks.
Mobil 1 75w90 and LE-607 seem to be the most popular around here. I don't think you can go wrong with either one....I wonder what was the factory fill.....hmmmmm
Originally Posted by JSR_AP2' date='Feb 14 2005, 03:37 PM
I use LE-607 90W fluid. The OEM fluid that came in the diff is 90W, so I'm continuing to use 90W. I don't see a problem using a good 75W90, but since I can get LE locally, I went that route.
![revto9k.gif](https://www.s2ki.com/forums/images/smilies/revto9k.gif)
