dif fluid
dif fluid
I have pmed a few ppl and they said all i needed was the basic ratchet and sockets.. i got under my car and my basic ratchet and socket is to fat to fit on the difs fill bolt. do i need some kind of low profile ratchet? What size is the bolt exactly? i was getting a 15/16 socket to fit it but the wrench i have that size seemed to just keep slipping and it was going to strip the bolt so i stopped.
use a box wrench on the fill - there should be enough room to fit one
Originally Posted by ROTFLMAO,Oct 19 2008, 11:49 PM
Yeah. The box wrench will let you access the fill bolt. It is probably more important to have the proper torque at the drain anyway since there is less chance of a leak from the fill bolt. But if you are anal like me, then I recommend proper torque on the fill as well. The only way you can do that is to use a low profile socket, or cut it like I did.
Torque wrench on the drain bolt, box wrench on the fill bolt. sizes mentioned above. Torque the drain bolt (I want to say 31ft-lb, but it might be 29), then use muscle memory to try and torque the fill bolt to the same number. It is NOT critical that you torque this 100% accurately, but you just don't want to over torque it too much. Slightly undertorquing is ok.
