Diagnosis: feels like it’s dropped a cylinder
No CEL, car was not used for about 2 weeks in which I simply filled it up half gas and got new tyres for it. Car was perfect prior.
Suddenly it started sputtering and hesitating on acceleration with no power.
Any idea what might the cause!
Would have a look at spark plugs,would not keep running it either
Not knowing the problem wouldn't like to advise.worst case would be bore and piston pick up ie friction damage =another engine.
Driving this car is likely to be more expensive than towing it. You may have already driven it too far. Stop driving ASAP unless you're already planning to replace an engine.
7smurfs (06-06-2022)
Damaged cat?
Bad gas? Issue seems to coincide with fueling up, if I read that right.
