deployed airbag
deployed airbag
well i got into a self-accident and airbags deployed. if i were to follow the DIY steering wheel removal n just take out the deployed airbag, could i just replace it with a new one? both fronts deployed so im wanting to change out both. people tell me ill have to get the module too, true? cant i just take out old n put in new?
please any help is appreciated...
pics of the bumper, sorry no camera when incident happened...
n could anyone tell me what this bent peice is called? n could i get it at the dealership? (the bar that the front bumper screws into)
Originally Posted by Sideways,Nov 20 2007, 02:52 PM
The seat belts need to be replaced too.
The bent piece is the radiator core support. It's welded to the car. You really need to go a body shop for the repairs.
Given the core support damage and airbags deployed you may want to contact your insurance company. Even a 1000$ deductible will be less than repair cost.
Originally Posted by mikegarrison,Nov 20 2007, 01:58 PM
And the SRS module, located under the radio.
slows2k, its not welded, its the bar that comes before the radiator support. there was 4bolts holding it in behind the reinforcement bar...was going to take it out but ran out of daylight n time...
really low on money right now (home issues). luckily i had a spare steering wheel (w/ airbag), reinforcement bar, front bumper (knock off veilside) laying around. so ill just need to go get the SRS module and seatbelts. yea?
welp just looked at the Helms, SRS module looks pretty simple to install, but the belt tensioner looks like a PITA! so what would you guys recommend do first? just found out my bro had already changed out the driver airbag (not even sure if he did it right), but not the module.
would it be alright to change out the module for now, n seatbelt tensioner later?
the belt should be fine 90 percent of the time, check for blister and sign of pulls on the fabric.
the metal beam you can get it at honda,it's not likely for honda to weld that into the unibody.
the Srs stuff is very easy to replace, it doesn't takes alot of work, just some simple precaution like no wire it up when the battery is on
invest/steal a service manual and it's all there
