Deleting my soft top this weekend. Any tips?
Old 03-06-2013, 03:22 PM
s2000ellier's Avatar
Originally Posted by gizzard
I had to separate the roll hoop plastics to get to the soft top. I have everything reassembled but the roll hoop plastics won't snap shut and there is a slight gap between the two halves of the plastic. How do I get them to stick together?
They don't snap together they are bonded when the factory assembled them. You need to glue them back together.
Old 03-06-2013, 03:33 PM
Billman250's Avatar
Received 1,401 Likes on 839 Posts
Best advice, DO NOT separate the roll hoops. They are electrically heat-melted from the factory.
Old 03-06-2013, 10:57 PM
gizzard's Avatar
In the moment, separating the roll hoops seemed like the only way to remove the center console and the rear side trays. What's done is done. Any suggestions for bonding them back together?
Old 03-06-2013, 11:01 PM
Banned
HondaRehab's Avatar
There is no bonding them back together, they will need replaced
Old 03-06-2013, 11:02 PM
Banned
HondaRehab's Avatar
Also, look on the passenger side as to how the seatbelt should go back together
Old 03-06-2013, 11:29 PM
gizzard's Avatar
I think I might try super glue first. They split apart fairly easily so super glue might be an improvement.
The passenger side and driver side anchor bolt hardware aren't the same. I don't know if this is the way it should be or if it was modified by someone else. This is why I'd like to know the proper order.
Old 03-07-2013, 04:42 AM
Billman250's Avatar
I've have tried construction adhesive. I had the parts perfectly mated, taped up tight to cure, and no luck.
I'd imagine you will need a type of glue that slightly dissolves the plastic, like we used to use on plastic model cars.
I'm currently working with mechanics wire and jumper cables, to electrically melt/bond them back together just like the factory did only better.
Once I have the method solid, I will post a diy so everyone hold on to your hoops.
Old 03-07-2013, 11:28 AM
use nuts a bolts maybe that will hold up
Old 03-07-2013, 11:38 AM
JUSTINTHECOASTIE's Avatar
To hold broken roll hoops together, I drilled two small holes on the inside topside of the headrest hole.Then I used a black zip tie and cut the zip tie tail.
Old 03-07-2013, 12:13 PM
gizzard's Avatar
In the process of replacing the OEM brackets that are attached to the soft top with the CR brackets, the driver's side (left) corner gusset that fits over the bracket needs modification. The passenger (right) side fits perfectly. The driver's side gusset needs to have 4 of the 7 holes enlarged by a few millimeters.
Euroflavor
07-12-2011 07:00 PM
bnag0
01-28-2011 01:20 PM
Ellington
05-10-2010 06:25 PM
it'S2klean
03-21-2010 03:16 PM
Vegas23
06-19-2007 11:00 AM
Quick Reply: Deleting my soft top this weekend. Any tips?
