Defi Gauge Install
Defi Gauge Install
I finished installing my Defi boost and oil pressure gauges by using one of the write-ups on here.
I must say wiring is definitely not my strong point haha
I ran the 3 wires (red, orange, and white) to the fuse box's gauge lights, battery constant 12v, and ignition sockets.
Problem: My brand new battery keeps dying now. It will charge, but if I leave the car sit for a day or two it wont start.
So my question is.. is my wiring wrong? I dont think that I should have anything plugged into the battery constant 12v???
Also, I read that I can combine the orange and white wires, is this true?
If someone could please explain the situation, I would greatly appreciate it.
Thanks
Thanks
That's how mine is wired up. No problems. Perhaps you have something else installed that is drawing power? Do you have a voltmeter? With the car off, check the voltage across the battery terminals to see if there is a large draw. Even if you had the wiring mixed up, I can't see how the Defi gauges would drain it within a day.
Hmm okay well i think it is my yellow top battery that is bad.
It won't hold a charge to save its life haha.
Even with a charger on it, the car still wouldnt turn over.
So I took it back and had it replaced under the 3 year warranty.
I made the mistake of storing the car over winter with the batter still in
So today, I just put a new yellow top in it and we'll see if that fixes my wiring "problem" haha
bringing back an old topic because im still having trouble..
with a new yellow top battery and the 3 wires from the defi gauges are plugged in to the gauge lights, ignition, and v12 constant in the fuse box.
but my car still dies after a week (7-10 days) if i dont drive it.
if i drive it every other day, its fine and i never have a problem..but if i let it sit for a week it wont turn over..
should the gauges really be plugged into the v12 constant?
any advice would help!
alright well the v12 constant is definitely getting power when the car is off,
i unplugged the middle wire a while ago and the gauges still work (for some reason)
even with the middle v12 constant wire pulled, the car still dies after a week of non-use!!
