DBW engine stuttering
Hey guys, lately I've had some issues with engine stuttering. A few symptoms
1) Almost every time I come out of gear my RPMs drop to 800-900, the car shudders, and it jumps to 1200, then back to normal idle of 950-1000.
2) Very occasional stalling. (Similar to 1)
3) The car will just drop power. 1st, 2nd, 3rd gear, doesn't matter. Usually for not more than a tenth of a second, but can sometimes be for an entire second. It even happens in cruise control. I recorded it to demonstrate:
Update: recording of shuttering idle, and engine COMPLETELY unresponsive to throttle input:
Update 2: I realized that #3 almost ONLY occurs at 3600-3800 RPMS. I used to have a small rattly sound at this RPM, as well, but couldn't nail down what it was before it went away. It sounded like it only came from the passenger/exhaust side of the engine bay, and underneath, so we assumed it was a sort of resonance with the exhaust system.
Does anyone have any ideas? I swapped the spark plugs, cleaned the injectors, checked the Accelerator Pedal Position Sensor, but I'm not sure what's wrong.
Thanks in advance!
Thanks in advance!
Any CEL codes?
Spark plugs are in good order? Try a MAP "whack?"
What plugs? Torqued to 22-24 lb-ft? (Grasping at straws here.)
-- Chuck
-- Chuck
Unplug your battery for a little bit to reset your ecu. When you reconnect your battery and the car dips to a low idle do not give it any gas, it is a learning ECU and will correct itself on it's own. Drive the car around for a little bit, again do not give it as gas when the idle dips. If you've tried this and the problem persists, then try cleaning or replacing the IACV.
Update: when recording the idle dropping low and stuttering, about halfway through the video the engine became completely unresponsive to the throttle for over 5 seconds. Then, and audible clunk is heard from the engine and throttle response is restored.
https://youtu.be/0O-DDwkQI4s
