Dash cluster flashing
Old 10-16-2009, 09:58 AM
Wateke's Avatar
My 01 does the same thing but only when a lot of current is drawn from the battery(in cold weather) to start the engine or if it sits in my garage for more than 4 0r 5 days without running, because of battery getting trickle discharged from my alarm.
Sometimes is pretty bad that it also beeps. But its only the battery so I don't worry about it.
Check for anything that may be discharging your battery.
Old 10-19-2009, 11:19 AM
FISH22's Avatar
That would explain why I only notice it when it's colder out and not in the summer.
Old 10-19-2009, 05:37 PM
rosscoe21's Avatar
Mine does it at idle only. It does it after the engine reaches operating temps. As soon as I touch the throttle it goes away.
Old 10-21-2009, 06:31 AM
FISH22's Avatar
If I've only noticed mine on startup, I'm assuming it's a weak battery.
Old 10-22-2009, 04:24 PM
ronnuke's Avatar
replaced diode pack on my alternator to fix this on mine.
The original battery had gone bad causing the diode pack in my alternator to go bad, hence the pulsating dash. New battery did not fix it, had to replace the diode pack.
Old 10-23-2009, 07:48 AM
terahertz's Avatar
if it flickers with your idle, it's your alternator diode pack (rectifier) like ronnuke said. mine did the same flickering thing and i replaced it with a used alternator, which fixed the problem.
mine only flickered once warmed up and idling at 1000 rpm or less. cold starts and any rpm higher than 1000 stopped the flickering.
Old 10-23-2009, 07:16 PM
MasterForce's Avatar
same thing happend to my 07....but i didnt replace the alternator. i bought a new rectifier assembly and replaced it. flickering went away.
Old 10-24-2009, 10:50 AM
terahertz's Avatar
yea i was thinking about doing that too, but getting my hands on a used alternator was much cheaper than getting the rectifier thing from honda for me.
Old 10-25-2009, 09:02 AM
gene20354's Avatar
I posted a video
start up video
Old 10-26-2009, 01:24 PM
FISH22's Avatar
Originally Posted by gene20354,Oct 25 2009, 12:02 PM
I posted a video
start up video
Mine is JUST like that.
Quick Reply: Dash cluster flashing
