Dash cluster flashing
Old 10-14-2009, 08:20 AM
gene20354's Avatar
Thumbs up Dash cluster flashing
My dash cluster has started flashing when I start the car. It goes out for about a second and then comes back on. Has anyone else experienced this? I was wondering if it has always done this and I have just never noticed. If this is abnormal, what can be causing this to happen?
Old 10-14-2009, 09:08 AM
foxy_s2k's Avatar
Video.
All the instruments light up then they all go out, except the ones that should be on at the time (such as speedo and rev counter), if yours is doing something else, get a vid.
Old 10-14-2009, 09:10 AM
croftoncustoms's Avatar
Sharkbite , my bud out here in NM has the same problem. Does it when he drives too. Its not very noticeable, but it does do it for sure. His is a 05 GPW. cant figure out what it is other then some wiring short somewhere
Old 10-14-2009, 09:44 AM
dammitjim's Avatar
Alternator?
Old 10-14-2009, 10:18 AM
JackS's Avatar
I asked this question concerning a Celica I have several months ago. Never got an answer. This began right after a new battery was installed and this did somewhat or almost completely dissapear in the last couple of years. I had to guess that it was electrical and that it had something to do with the alternator or the battery. I'm thinking that since the battery was new, it may have been overcharged or the alternator overcharged the already new battery. Never a problem though, just odd and enough to cause some initial concern.
Old 10-14-2009, 11:31 AM
S2KJESSE's Avatar
having the same problem, doesnt matter the temp...does when im idling or when im driving, does it as soon as i start the car untill i turn it off, i jave an 03
Old 10-14-2009, 11:32 AM
AngryTurtle's Avatar
Originally Posted by 9volt,Oct 14 2009, 01:44 PM
Alternator?
Ive heard this is a possible cause too.
Old 10-14-2009, 11:51 AM
dammitjim's Avatar
If it does it constantly then it is probably a bad ground or the alternator.
Old 10-14-2009, 11:57 AM
FISH22's Avatar
I've noticed this same exact thing on mine. It's very rare and seems to happen only when it's cold out. Also, it only happens on startup... the whole cluster flickers for a split second.
I've had no other issues with it, and it's been like that for 3 years.
Old 10-14-2009, 10:00 PM
spets's Avatar
the startup flicker is probably ok, I'm guessing its the airpump kicking in before the car stabilizes itself.
Quick Reply: Dash cluster flashing
