Dash bulb question (pic)
There's a big thread about bulbs https://www.s2ki.com/s2000/topic/707.../page__st__150
but i'm a little bit confused the type of bulb i need just for the gauges.
The thread described the bulb mostly for the controls which I'm not interested.
Can someone tell me the type of bulb in the picture and where to buy a higher intensity which is better than the stock.
Thank you
Thank you
I dont know anything about this stuff but i have a question..
Where can i get some bulbs? I took off my cluster and found out its missing the CEL ABS EPS bulbs
I plan on taking off the cruise control BULB and putting it on the CEL or does it need a specific one?
Are they mentioned in the owners manual?
The info has to be here on S2KI someplace.
Info from Maintenance manual located on pages 22-53 thru 55 depending on year of car. I assume this is an early car (2000-2003) guessing by the layout of the bulbs.
In first photo
larger bulbs are 12 volt 3 watt
smaller bulbs are 12 volt 2 watt
In second photo
All bulbs are 12 volt 1.12 Watt except
Cruise Control indicator (7th from left in your photo) is 1.4 w
In first photo
In second photo
I need to know the type so i can buy a more intense LED or incandescent bulb ...thanks anyway..
In first photo
In second photo
In first photo
In second photo
