danielg 0 - S2K Transmission 1
Old 12-23-2006, 01:36 AM
terahertz's Avatar
it means redline clutch in gas off "bang into second" clutch out gas on as fast as possible
Old 12-23-2006, 01:43 AM
RACER's Avatar
clutch/throttle timing plays a major role in this scenario. Let out on the throttle just enough just before disengaging the clutch, disengage clutch, shift up, let the clutch back out and slam back on the throttle as hard as you can = slamming parts together at full force, also known as banging gears.
To the thread starter
Old 12-23-2006, 05:05 AM
SpitfireS's Avatar
Great pictures though
danielg Posted: Dec 23 2006, 07:34 AM
I'm really wanting a tranny that's going to stand the abuse of banging gears with a 4 puck clutch...
Is that a race clutch disk without springs?
What PP do you use?
my intent is to stay NA, but who knows
How about 4.56's?
Almost like boost and a little less stress on the drivetrain upwards from the diff.
Old 12-23-2006, 06:02 AM
Slows2k's Avatar
I've seen it before on cars with 2x stock power. It your case the failure is from the additional shock loads caused by your driving style and aggressive clutch.
Old 12-23-2006, 07:49 AM
danielg's Avatar
that's what we were thinking...
I have a competition clutch 4 puck spring loaded w/ their PP & ultra lightened flywheel.
I also refer to "banging gears" as shifting as fast as possible, its just something my friends and I have always said.
What suggestions do you guys have as far as fixing it? I'm probably going to do the final drive at the same time since thr diff is just right there. 4.77's here I come.
right now i'm thinking AP2 tranny sent to kings motorsports for their strengthening, but my mind changes every couple hours.
*edited cause I can't spell.
Old 12-23-2006, 09:34 AM
BozzSpeed S's Avatar
Btw Daniel, the final drive is in the diff. aka ring gear
Old 12-23-2006, 09:51 AM
Slows2k's Avatar
You'll need a 1-2 gear and synchro set, and a mainshaft. Not to mention cleaning out all of the debris from the damaged gears. You may also have damaged synchros on other gears. It would be more cost effective to find a complete used trans.
Old 12-23-2006, 09:54 AM
John_Z's Avatar
I would rebuild with cryo'd parts.
Old 12-23-2006, 10:29 AM
danielg's Avatar
I know, since the driveshaft isn't connected, its in plain sight.
I'm very much so considering a used ap2 tranny....has anyone done this? also how would you know that a used tranny is in good working order....I don't want to buy one and find it has problems...hence the reason I keep leaning towards a rebuild
Old 12-23-2006, 01:31 PM
HARDtoTOP's Avatar
Looks like you have a very nice camera. Great pics. Good luck with the tranny.
Quick Reply: danielg 0 - S2K Transmission 1
