Damn you tick-tick-tick
Hello guys,
I have this ticking noise coming from my left front wheel only when I turn right.
The ticking noise is coming only when the car is warm up (especially the brakes, I think)
Please help me, any suggestion...
http://www.youtube.c...h?v=Wk1PMzD_vxI
Originally Posted by cbayman' timestamp='1315669299' post='20960552
Sounds like something hitting the dust shield. Maybe a pebble caught between the hub and the shield?
Pebble was the first thing I checked.
I can hear it ONLY when I turn right with warm up brakes
Originally Posted by S2johnyK' timestamp='1315673675' post='20960686
[quote name='cbayman' timestamp='1315669299' post='20960552']
[/quote]
Thank you once again
Ok, let's see:
Brake pad wear indicator: CHECK (the pad has quite enough "life" BUT the pad wear is uneven between its two sides with small difference thought)
Loose lugs : CHECK (lugs were torqed enough)
Wheel bearing: CHECK (replace with new before 500 miles)
Wheel hub: CHECK (replace with new before 500 miles)
When I jack it up nothing happens.
If the brake pad wear is responsible for the noise, shouldn't it be different type of noise like scrubbing?
The fact that you recently replaced the bearing and hub + aftermarket parts (at least the disk isn't OEM) means this is most likely related to that work. From your video it still sounds like something hitting the splash shield. Maybe the shield was bent when the hub components were pressed out or reinstalled. Inspect around the disk and look for possible interference points. Also post details on the work performed - who did the work, torque used on the hub nut, etc. Include the details of OEM and aftermarket parts used. Most likely somebody will have used the same aftermarket parts and will be able to help.
