Damage Assesment Help *Lots of Pics*
Originally Posted by 2poor2mod,Oct 20 2009, 12:46 PM
start measuring things from side to side to see if you can come up with anything out of the ordinary.
Pull the parts off and compare them to each other. Its hard to tell if the LCA is bent, but it doesn't look like it to me.
The LCA definitely looks bent, to me. I can't really tell anything about the knuckle, though. I'd start by just replacing the LCA and taking it in for an alignment. If they can't get it to OEM specs, then you know you still have work to do.
Originally Posted by jbgordon,Oct 20 2009, 11:46 AM
What's up with all the dings on the driver's side door?
And to the OP, you could probably buy used suspension components from a part out. Check the For Sale forum. Probably no need to waste money on a rack yet... you bent parts.
