Cylinder Rattle/Noise
I'm going to resurrect this post. Seems I'm starting to hear a very familiar sound. Sounds like the beginning of the TCT going again. It's not very loud right now, but I've also noticed a delay (and sometimes nothing at all) in VTEC kicking in.
I have only put 5k on the car since I changed the TCT. Is it possible that it could go bad (or perhaps I got a bad part) in 5k miles?
Has anyone experienced this? Any ideas?
Thanks in advance for your help!
-j
-j
-j
-j
It is very possible that the design of the TCT has not changed sine your last post
It's not a bad part, it's in the design.
Find the thread about sandblasting the worm gear and you'll be good for a very long time
Originally Posted by rob-2,Feb 19 2010, 02:14 PM
Is it the same sound as before?
unfortunately it probably is the TCT again. A lot of people blame Mobile 1 oil. Some people never have this problem but the ones who do seems like it keeps coming back every 5-10k miles. Did you keep your old TCT? If you kept your old TCT you can sandblast the worm gear and rebuild it so you can swap it out. Thats what I have done I always have one ready to swap just in case I hear that lovely noise start to come back.
Thanks for the replies. I'll let you know what I find.
Is it strange that in a pinch I put a quart of Mobil 1 5w20 in the s2k and I haven't heard the TCT noise? I only drove about 10-15mi...
Planning to do an oil change today back to the Mobil 1 10w30.
Switch from mobile 1 man. I was hearing some TCT noise my self and I was using mobile 1. I switched to royal purple about 5,000 ago and the noise has stopped or if its there its to faint to hear. I'd change oil brands before changing the TCT again. Save some money man.
So I'm resurrecting this post once again. Since I originally started this post (2009) I have replaced the TCT three times in my 2003 s2k (77,000+ mi on the clock). The last replacement was January 2012 (10 months ago - which is completely ridiculous).
Well the noise returned about a week ago. Figuring it was the same issue I put off fixing it till I could order one online (still waiting for delivery). I drove the car probably 50 mi or so to and from work. Two days ago I was driving home from work and started to hear a new, "knocking" sound. This is louder and more consistant sound than the standard TCT "ticking" noise. The "knocking" sound is quite worrisome since it sounds like a valve knock. I've taken a video and posted it out on youtube (sorry for the poor lighting): https://www.youtube.com/watch?v=cHcdW0Kr4hU
The noise only appears when you give the car gas. The noise increases as the RPMs increase. It is not present at idle.
I checked the oil level in the car and it was low. I added a half quart, but no change. I made the switch from Mobile 1 to AMSOil about a year and a half ago. The car has never had a valve adjustment.
Not sure what else to do? Not sure just a TCT swap will fix it this time?
I appreciate any help!
Thanks
-j
Thanks
-j
Thanks
-j
Thanks
-j
Talked to a buddy of mine who has a shop. He saw the video and thinks it may be the Main Bearing. Anybody have any thoughts?
Thanks!
