Cylinder Head Removed
Old 12-17-2009, 06:16 AM
SPFSkyline's Avatar
They did compression test and leak down. I asked if they heard a leak on intake or exhaust side, but they acted like I was crazy to ask. I already had the car back and told them I wasn't going to have them do the work, so I doubt they felt like being helpful. I just have the ticket with mechanics notes.
Old 12-17-2009, 04:52 PM
SPFSkyline's Avatar
Took some macro pics of the head gasket below. It appears to my simple mind to be looking a little rough between the cylinders, especially 2-3. I tried to label as best as possible, lower numbered cylinder in on the right. I did both sides of the gasket. When I put this thing back together, what all gaskets should I replace... head, intake, any others?
Album
Cylinder Head Side of Gasket
Head Gasket
Cylinder 1 and 2
Cylinder 2 and 3
Cylinder 3 and 4
Block Side of Gasket
Head Gasket
Cylinder 1 and 2
Cylinder 2 and 3
Cylinder 3 and 4
Old 12-17-2009, 05:15 PM
Slows2k's Avatar
The coating came off the gasket (which is normal) There is no obvious combustion path across. I'd bet the valve seats are done.
Old 12-17-2009, 07:20 PM
SPFSkyline's Avatar
Bummer. Well, I guess its to the shop with the head. Thanks for the help!
Old 12-17-2009, 08:07 PM
Kirpich's Avatar
Hey, let us know!
Old 12-17-2009, 08:12 PM
Slows2k's Avatar
If not I've got a like new cylinder head from a 04 AP2 that could use a good home.
Old 12-18-2009, 05:38 AM
SPFSkyline's Avatar
Do head studs need to be replaced when rebuilding? One of my friends said something about them not really being ment to get reused.
Old 12-18-2009, 06:51 AM
lowerlattitudes's Avatar
yes, you should consider those as one use only. Once they have been properly torqued during initial installation, they literally stretch and will not set correctly again with the same torque values.
People have re-used them, but if you love your car, why bother...
Old 12-18-2009, 07:20 AM
SPFSkyline's Avatar
Any other helpful hints? New head studs, head gasket & intake manifold gasket... what else?
Old 12-18-2009, 08:16 PM
Slows2k's Avatar
S2k head bolts are not torque to yield. They can be safely reused after inspecting the threads. Used bolts have a different torque angle setting than new
Quick Reply: Cylinder Head Removed
