Cylinder Head Rebuild Due to Burnt Exh. Valves
#21
Regions will specify different maintenance intervals and sometimes different oils. I believe it wa American Honda than began to specify 5w20 when 30w was specified in Japan on the same cars. This was to meet CAFE regulations. Japan still eats whales and has current emissions standards similar to what we had in the late 80s. When the S2K came out, manufacturers were pushing for longer tuneup intervals because they became an indicator of quality for the consumer. If valve adjustments were to be required every 15 like they should be, the tuneup interval would be similar to that of an exotic.
#22
Biggest issue is finding no clearance on the valves. This is why they burnt.
In my book, the 100k service interval for the valve adjustment is pathetic. If the va was done earlier, this would not have happened.
found 3 valves about .002 too tight on a 2002 car today. Little preventative maint saved the guys engine.
#23
IMHO, it's not the absolute amount that the valves are too tight --- but the change in duration of contact of the valve face with the head. So, kinda depends on how hot your cam setup is and how fast (RPM's) the engine is turning. Duration of contact is how valves transfer heat to the head. Too little transfer time = burnt valves.
#24
That's some abnormally high compression in cylinder 4.
