Cylinder FRP Gouge - Salvageable?
Yep. The retainers turned out to be fine and I shouldn't have messed with them. But since I have been close to a mild money shift a couple of time in 6 weeks, I figured there was a good chance the previous owners had done it at least once in 15 years. Should have just inspected them.
Potentially expensive lesson. But at least I know how to do a top end on this car now.
So far so good!
Compression test results?
If its me, I'm feeling relieved with those numbers. I think you are going to be fine. I'm no expert though. Wait for others to chime in.
Well, I wasn't able to salvage the compression tester I used a few weeks ago prior to the cylinder damage and had to buy a new one today. Just performed the test and here are the results:
Test prior to damage: 200, 190, 205, 205
Current test: 195, 190, 210, 210
Cylinder #3 was the one with the damage so I feel good that it didn't go down. I assume there is some variation due to the change in equipment but overall I'm satisfied since there wasn't a step change.
Should I be concerned over the relative differences in the pressures where they are and have been?
Gouged cylinder was #3, you'd never see it affect compression that low in the cylinder for obvious reasons, the main one being compression happens at TDC not middle dead center.
It's all about eliminating variables in a diagnosis.... even if that diagnosis isn't needed yet, and that variable is totally off the wall.
skool u
03-14-2012 10:39 PM
