Cylinder 2 appears to be leaning out- what causes this?
Old 04-16-2012, 01:08 PM
TerminatioN's Avatar
Were the injectors cleaned and flow tested before or after the problem started occuring?
Old 04-16-2012, 01:12 PM
BrockB's Avatar
technically these tests were done about a month before i took off the head and discovered that issue. I had no idea how long that issue with cylinder 2 may have been happening. It could've been over a year for all i know because i never took off the head
btw, the reason i took off the head was because a valve stem broke from a valve on my intake side and i had to get it, along with the fact i wanted to clean and inspect things. Thats a separate issue though.
to be absolutely sure,
running lean would be the only cause for the whitish wear on the valves,
and nothing else?
and you can tune individual cylinders on flashpro, right?
Old 04-16-2012, 06:09 PM
s2klariat's Avatar
Running lean or valve clearances being too tight on that cylinder will cause the valves to turn white like that. So there is a possibility that before you had your injectors cleaned and flow tested that one of them may have been clogged and causing that cylinder to run lean?
duffsr
11-11-2015 04:13 PM
MilanoRedDashR
05-11-2013 10:03 AM
andersayz
05-26-2006 04:54 PM
SFRS2K
03-29-2005 12:07 PM
Quick Reply: Cylinder 2 appears to be leaning out- what causes this?
