CV cup swap and still have an issue....
if they were that bad, then it's def possible that was your problem. the vibration is typically noticeable under load (accel), but if the contact surface is bad enough, then i guess hard braking might produce enough load to cause vibration
interested to see how it works out, hope you get it cleared up without too much hassle
If the pit is bad enough, you can definitely get vibration under deceleration.
Most of the time (since the load is less) it is not a problem.
Replace the one bucket and it will cure it.
The pure opposite of accelaration is engine braking - from the CV's point of view.
Using the brakes should have nothing to do with it.
The hardest engine braking is downshifting without rev-matching.
So find a speed in a gear at which you're sure one gear down can handle (if you know what I mean).
Then downshift and "catch it" using the clutch and nothing but the clutch.
If it vibrates doing that its the cups.
IMO.
IMO.
IMO.
IMO.
Yes. It's the decel that really pronounces the problem. The cup needs to be changed, thank you!
I think the idea of swapping the boots was done during a race weekend where someone needed a "quick fix" just to finish the weekend. I'm not convinced it was ever a long-term solution rather than "delaying the inevitable"
Sry to bring this thread up again, but I'm having vibration issues coming from the rear as well. Problem is, I installed a Magnaflow catback exhaust around the same time this started happening ... which is also when I started visiting the track more. So I'm not positive if it's the noise of the exhaust or a possible clearance issue (magnaflow sits close to some stuff and not sure if it's hitting anything under load) .... or if it's the CV boot issue. Is there a way to pinpoint the problem and eliminate the possibility of exhaust noise/vibration outside of putting the stock exhaust back on? Overall, I like the exhaust and would rather not take it off, just to find it's the CV boots, then have to put it back on again
CV boots have nothing to do with this, it's the CV drive bucket of the axle that gets pitted.
If you can make it vibrate when accelerating, and turn the vibration off instantly by letting off the gas and decelerating, then it is 100% a pitted CV bucket.
