CV cup, how to do without ballpoint separator?
EDIT - Did not want to make a whole new thread..
How can I get the axle out without poping the balljoints, i remember reading this was optional.
AKA what is the easiest hassle free way to do it? If it's a lot easier poping the ball joint i will just buy the tool.
Will be doing this soon:
https://www.s2ki.com/s2000/topic/241...diy-with-pics/
I want to get new boots and clamps, what else should i get?
Also is there anything that may get stripped or broken (i will order as precaution, all the parts seem cheap)
42017-S2A-010 001 002 BOOT SET, INBOARD
42018-S2A-020 002 002 BOOT SET, OUTBOARD
42310-S2A-951 003 001 DRIVESHAFT ASSY., R.
42311-S2A-951 004 001 DRIVESHAFT ASSY., L.
42320-S2A-310 005 002 JOINT, INBOARD
44014-S2A-953 006 002 JOINT SET, OUTBOARD
44327-SV4-305 007 002 BAND, JOINT BOOT (DOUBLE ROLLED BAND)
44327-SX0-C02 008 002 BAND, OUTBOARD BOOT (NIPPON HATSUJO)
44327-SDA-A11 008 002 BAND B, DRIVESHAFT (OETIKER LIMITED)
44329-SV4-305 009 002 BAND, SHAFT BOOT (DOUBLE ROLLED BAND)
44329-S2A-N01 010 002 BAND C
44337-SB0-300 011 002 RING B, STOPPER
44338-SM1-300 012 002 CIRCLIP (26MM)
90181-S2A-000 013 012 BOLT, FLANGE (10X26)
90305-SD4-003 014 002 NUT, SPINDLE (24MM)
90002-S10-000 015 012 NUT, FLANGE (10MM)
In all honesty, you wont need a single part.
The clamps are stainless steel, and designed as such they can be taken on and off endless times.
I've done dozens of bucket swaps and never bought a single part. I have never seen a boot failure in 9 years of doing so.
I didn't have a long enough breaker bar or arm power for the axle nut so I left it all alone and managed to push the cup out of the axle. After you unbolt The cup has a useless shaft that does nothing but protrude into the diff and flip you off like a middle finger. There should be enough play in the CV joints that you can push hard enough to clear the protruding shaft off the diff. It may help o unbolt the sway bar but I didn't do it.
