cutting Question....
Going to cut my airguide tommorow for my custom spoon duct install. Bought a mini hacksaw and those metal saws cut plastic so good....Should I be worried because of the small pieces of plastic coming off and hitting the radiator? Or is this not a big deal? I'm cutting a small square piece and shouldnt be to much debris...don't want to deal with taking it out and cutting. thanks!
I wouldn't worry about it, but I guess to be safe you could spray the radiator down with water to knock off the bits of plastic. Or if you have a compressor just spray some air around?
you will be wise to remove the guide for the install. Then it also won't matter where the bits go
(I would recommend using a razor knife for the cut BTW, hacksaw is overkill)
infinitys2000
04-21-2003 05:56 AM
