Crunchy Clutch Pedal
About a month ago I started noticing that my clutch pedal feels sort of crunching as it travels (both engaging and disengaging). Is there a maintenance procedure for lubricating the cable or pedal?
This is a 2004 model year but only has 23K miles (and rather well maintained).
Thanks for any suggestions.
change your trans fluid
remove the slave piston, grind the nipple that it most likely has developed flat, regrease, reinstall.
PM me if you need some more info//it should be all in the FAQs somewhere.
Mine felt a little crunchy at the bottom of the pedal travel for a couple of months. When the friction point started moving lower, I looked and found leaking fluid from the master cylinder. Replaced the master cylinder, feels good as new.
