Cruise Control Removal
Old 12-08-2005, 12:47 PM
AusS2000's Avatar
The Cruise is an add on and not part of the ECU. Removal shouldn't cause any problems. There is the actuator and cable, the control switch, and I believe a control box under the dash.
The reason I know all this is that Aus Ss (and infact most other markets) don't have cruise but I added it to mine. I went with a very similar unit made by Rostra.
The steering wheel control on mine is an RF transmitter so there is no wiring to the control box. I believe this is not the case with the US OEM. I had to notch the shroud a bit to fit the button pack and still use the horn. Not sure what AHM have done to it but it shouldn't be noticable.
Old 12-08-2005, 12:58 PM
RWD_RCKT's Avatar
Originally Posted by Emil St-Hilaire,Dec 8 2005, 01:28 PM
Would it fit around there?does it hold the battery at the same time?
Those would be the only 2 places I found!
It only works with a "small" battery (like the Buddy Club battery group buy, or Odyssey 680 battery size). Seeing as how it looks like you have the factory battery size, my solution would not work for you... unless you wanted to buy a new battery.
I will take a picture of it tonight when I can get to my car.
elsinoreboy
12-13-2009 01:47 PM
21k
08-29-2009 06:10 PM
h2k
08-21-2009 12:26 PM
Avionics86
08-03-2009 10:20 AM
Quick Reply: Cruise Control Removal
