Cruise control not working
Old 05-24-2014, 03:40 PM
Polimangas's Avatar
Originally Posted by c130turboprop
does ur horn work?? if it doesnt, then the problem is the srs reel. i just had to change mine cause the cruise and horn uses the same power wire through the reel. hope that helps
Yes my horn works.
Keep the responses coming, I really appreciate all the feedback!
Old 05-25-2014, 08:42 PM
andrew87890's Avatar
have the same issue and my srs light is on and my horn works, the cruise light goes on and the set dont work. 07 S
Old 05-25-2014, 08:44 PM
Originally Posted by s2k_ssm
Check your clutch position switch, make sure the nylon plug is still there
where is this located?
Old 05-27-2014, 05:12 PM
s2k_ssm's Avatar
switch is B but the nylon plug is C. its on the actual clutch pedal
Old 05-27-2014, 06:09 PM
mongomery1234's Avatar
You'll see two pieces going off the gas pedal one is the throttle and one is the cruise. As far as I can tell that's the only thing related to the cruise.. There's a bracket on the pedal with the cord running to the module under the hood. I can possibly get pictures of my setup I took off tomorrow so you can compare the two.
Old 05-28-2014, 12:21 PM
if i pull the srs fuse and put it back in will the light go off?
Old 05-28-2014, 12:51 PM
Only if the problem is solved. If not it will come back on.
Old 05-29-2014, 06:12 PM
Utah S2K's Avatar
Originally Posted by RTZX9R
I had a similar issue years ago. I kept pressing the cruise set button and it eventually took. Worth a shot.
Stupid question but you are pressing "set" button on the steering wheel after pressing the dash switch right? The dash light indicates you are actually cruising after setting your speed...if that makes sense.
Utah
Old 06-03-2014, 09:45 AM
i press my cruise button and the dash light dont even come on.
Old 06-03-2014, 09:49 AM
V6 Donut's Avatar
could be the box under the dash.
I have one if you need it, just toss me some gas money with shipping.
Quick Reply: Cruise control not working
