Cruise control not working
Old 05-21-2014, 12:01 PM
Polimangas's Avatar
Default Cruise control not working
So I haven't used my cruise control in quite some time. Today I pushed the cruise control engagement button, light is on on the button, but no "cruise control" light on dash.
I checked the #6 (15AMP) fuse under the dash, it was fine.
Does anyone have any ideas why it would behave like this???
BTW... I have a 2003 S2000 with 54,000 miles
Thanks in advance.
Old 05-21-2014, 06:30 PM
Polimangas's Avatar
No one
Old 05-22-2014, 07:09 AM
Polimangas's Avatar
I can't be the only one with this issue?!?!?!?!?
Old 05-22-2014, 12:25 PM
s2k_ssm's Avatar
Check your clutch position switch, make sure the nylon plug is still there
Old 05-22-2014, 12:58 PM
Polimangas's Avatar
Thanks, I'll give it a shot!
Checked it... still there.
Old 05-22-2014, 01:08 PM
mongomery1234's Avatar
I have the complete cruise system out of my car for sale if you need it and cant fix it anyway else man. Works perfect just pulled because I went with a Sparco wheel.
Old 05-22-2014, 02:56 PM
RTZX9R's Avatar
I had a similar issue years ago. I kept pressing the cruise set button and it eventually took. Worth a shot.
Old 05-23-2014, 02:21 AM
c130turboprop's Avatar
does ur horn work?? if it doesnt, then the problem is the srs reel. i just had to change mine cause the cruise and horn uses the same power wire through the reel. hope that helps
Old 05-24-2014, 05:34 AM
neilscivic's Avatar
I have the same problem, except when I press my cruise button often it will work for one second then it will release the pedal and won't work anymore...
I have an 04 with 70k miles
Old 05-24-2014, 03:39 PM
Polimangas's Avatar
Problem is that the cruise control never engages... No cruise control light on dash!
Quick Reply: Cruise control not working
