Cruise Control Not Working
The other day while driving on the highway i noticed my cruise control doesnt work, ive researched and my horn also works. I made sure i press the button behind the wheel obviously and the dash light for CC doesnt come on. The only thing i can think of it after i adjusted my clutch if that can effect it. Any ideas would be much appreciated.
You mentioned this started occuring after a clutch pedal adjustement--If the clutch safety switch is engaged then cruise will be disabled. Check your clutch pedal and make sure it is pressing that small button switch.
it is pushing in the button of the clutch pedal. Theres no light when i click the cruise control button behind the steering wheel; but i dont remeber it lighting up when it did work
Make sure the cable is plugged in to the Cruise Control actuator. There is a little power connector.
http://www.dealerdirectparts.com/v/v...os/4465140.gif
its under the hood, also check the cable.
