Creak from rear suspension
Old 04-07-2009, 04:07 PM
  #21
SCCS2K's Avatar
I think most of us have had the hub nut issue at least once, including me.
This thread is something different, or at least is for me.
Old 04-07-2009, 07:22 PM
  #22
Hero's Avatar
then i'm wondering if you might have seized sway bar endlink bolts?
Old 04-08-2009, 05:30 AM
  #23
SC_Highlander's Avatar
In my case, I fixed the creaking by doing what Stratocaster suggested. I loosened the upper a-arm bolts and the shock bolts, loaded the suspension, then re-torqued everything. Not a peep from them since.
Old 06-01-2009, 11:43 AM
  #24
Sbeall's Avatar
I'm not getting a creak really but more of a dull clunk/bang and sounds like rear, drivers side.
It started when the car had about 105k on it. It was mild at first and then got louder and happens mostly when going slower over bumpy roads or railroad tracks, sometimes when backing up or moving forward. I really don't think it's the u-joint or even hub nut issue, as I've had that noise for about 50k and have actually gotten used to it now.
I originally thought it was a broken shock since that's exactly what it reminded me of, so I replaced the shocks and at first and since the ride was firmer again, it seemed to go away but alas it was still there, just not as loud or obvious.
Would this be the upper a-arm problem, or other loose suspension connections?
Old 08-15-2009, 10:35 AM
  #25
jyeung528's Avatar
probably worn control arm bushings...
ChrisPackit
03-01-2019 03:33 AM
hybridb18
08-05-2013 08:04 PM
TrackStar
06-08-2010 11:48 AM
billiardboy904
02-02-2010 08:59 AM
Edlover
07-03-2006 08:11 AM
Quick Reply: Creak from rear suspension
