CrankCase breather
CrankCase breather
Is there any advantage to putting a K&N, etc, crankcase breather filter on the s2k? I know the effect would be minimal, but I ask because I noticed on both Speed Craft and UR's pics of their kits the crankcase has a breather.
If you are using an oil catch can, using a crankcase breather in addition will allow air into the engine without backing up oil into your intake. You would need the oil catch can otherwise you're still putting oil vapor into your intake path and thus defeating the purpose of using a breather.
no hes talkin about the 1/2" hose that comes off the top of the block that gos into the intake right?, i have a breather on mine, only because comptech's fitment sucks, so i just rerouted it with a breather.
Yes, that is what he's talking about. He's asking for the advantages of using one, and without an oil catch can to prevent oil buildup in the intake track the "advantages" are minimal.
if you put one on ur s2k will no longer be a environmentally safe car!!!!!! haha. the crankcase gasses are usually vented into the intake so that it is not released in to the atmosphere, so if you put the breather on it will just go out of that. now im not sure if the gasses coming from the crankcase are hot, but if they are i assume you can benefit from making the intake temps cooler.
k-jai
08-26-2011 10:23 PM
