Crank Pulley
Crank Pulley
Have anyone tried to, or have removed the crank pulley? I'm trying to pull mine off, however its giving me a hard time. I have the honda lock tool to hold the pulley in place while trying to spin the bolt and its not coming off. I have a long breaker bar as well. Any other ideas i can try? ALso, the motor is in the car.
It's a bitch....but it's doable. I like to wedge the crank holding tool with a long breaker bar against a solid point on the car....then it generally takes a breaker bar around 4-6 feet long to snap it loose. It's generally a PITA. Whatever you do though, don't apply heat whatsoever.
Wow! No heat huh? I was so going to try that. I guess ill eat my Wheaties soon and try it this evening again. We already broke a craftsman socket. We will try again. I am suppose to turn it to the left right to loosen? lol!
Yes, lefty loosy, righty tighty for our crank bolt. It is NOT reverse threaded. Good Luck!
This is the breaker bar that I have/use....
http://www.northerntool.com/shop/too...8359_200328359
Just get a 3/4 to 1/2 reducer and a 19mm 1/2" drive impact socket.
Got it off guys, just had to put some elbow grease in it. lol! Thanks, i used the socket and a long as breaker bar and pipe and the honda tool braced against the sub frame.
This is what we've been trying to tell you from the beginning. Use good tools, the right tools and a lot of force. No need to try this "technique" or that technique or using spray or heat or cold or waving your magic wand.
