Crank Bolt - Starter Bump?
Guys, why shouldn't a person resort to the starter bump method to loosen that beastly bolt? While hand cranking on it again yesterday with a 32" extension on a breaker bar and holder tool wedged between the EPS and it (rags between them to prevent scuffs) I lifted my engine up...left mount torn clean off... perhaps it was torn/tearing to begin with but I think "the beast bolt" took it's life while laughing at me
P.S. impact gun keeps failing to remove it. I don't have the Lisle socket though.
The starter isn't an impact. Its applying tons of torque, just like when you use a long extension handle.
Except with the handle you are resisting the torque right at the pulley with the pulley tool.
Using the starter, the resistance tontorque is coming from the rear wheels, via brake and being in gear. That counter torque has to de transmitted through the rear axles and cv's, through the diff and diff mounts, through propshaft and its cv's, through trans and trans mount, through engine and engine mounts.
Most of those things can easily handle that amount of torque. Perhaps the rubber mounts are the most vulnerable.
The cost of the Lisle socket pales in comparison to cost of new engine mounts. Even aftermarket oe style mounts. Even the cost of an impact gun plus the socket beats engine mount cost.
Starter bump will result is massive side loading of the crankshaft. The breakaway torque on that bolt is over 300 ft-lbs.
Use the holding tool or nothing.
P.S. Purpose of removing the crank pulley is not for a timing chain service rather to install my supercharger's pulley
I don't understand why this is still being discussed. I really don't.
Use the holder tool or the Matco/Lisle socket and be done with it.
There is no need to reinvent the wheel here.
I will say though, using a Milwaukee M18 fuel and the Lisle socket that bolt came out on the first ugga dugga, that Milwaukee got some serious torque; enough to pull the panties off a nun.
The following 4 users liked this post by Kyle:
Accordinglytuned (07-08-2021),
Mr.Matchbox (07-06-2021),
RolanTHUNDER (07-04-2021),
windhund116 (07-04-2021)
