Cracked Toda Header bracket
My car developed a metallic rattle at 4100rpm. The tab the mounts the bracket to the block cracked. The header has been on the car about a year, (7000miles) I have not called AKH about the problem. For all you Toda owners, check your header.
Originally posted by beroznikmal
Do you think that is might be due to the extra vibration that the SC contributes to the engine????
I wouldn't go blaming the SC, It's only been on the car 3 months and 4000 miles. The bracket on the Toda is about 1/3 the thickness of the original. I would suspect material thickness being insufficient being the most likely cause.
