cracked radiator
cracked radiator
so i drove my car almost 120 miles or more before i realized there is coolant leaking. i mean the temp was right in the middle which is normal. i have glad i didn't blow something u know. anyways i want to get a new one and was looking a the mishimoto for $240. what do u guys think? there are alot of good reviews on them anyways have them?
All,
Just want to add my comments about a cracked radiator. My S came from the sandy shores of Florida with a full length upper crack on the radiator. Come to find out, the overflow tube had 2-3 inches of packed sand in it, which caused the pressure to build once the radiator cap released. Also after normal driving I noticed my upper radiator hose was collapsed. It took a little investigating until I found that the clogged radiator overflow hose was the culprit. I called the radiator shop that replaced my radiator and SAMCO hoses and asked them to put the overflow tube on their 87 point inspection. The coolant system works perfect now.
So, word to the wise: Inspect, check and investigate (don't assume or overlook the obvious)
