Cracked oil pan
Old 12-17-2014 | 11:26 AM
Peti's Avatar
Default Cracked oil pan
I just discovered a pool of oil under the car and when I check underneath, I discovered a small (1 inch) crack near the oil drain plug. Did anyone have a similar problem and did anyone try to weld it? Thanks, Peter
Old 12-17-2014 | 11:50 AM
joes sled 2000's Avatar
i would replace it if possible . Welding it properly would require removal of the pan to begin with . i haven't seen or heard of them cracking without some sort of an impact .
Old 12-17-2014 | 12:00 PM
bgoetz's Avatar
Over torqued the drian bolt is my guess
Old 12-17-2014 | 01:13 PM
jkelley's Avatar
Used oil pans are pretty cheap. And if it's cracked from the thread hole, then you'd have to weld AND re tap the drain bolt which frankly wouldn't be worth it at all to me and you'd probably just be paying more.
Old 12-17-2014 | 01:22 PM
cosmomiller's Avatar
This may indicate an issue with crushable washers that should be NEW for every use, with proper torque when reinstalling the oil drain bolt after an oil change. A used washer may leak leading to an over torque to stop it resulting in a cracked oil pan near the drain bolt hole.
Old 12-17-2014 | 01:32 PM
S2KERRP2's Avatar
I have one thats pretty much brand new if you want it. Just PM me. where you located?
Old 12-17-2014 | 05:48 PM
Peti's Avatar
Thank you all for the advice. It must be the crushable washer as cosmomiller mentioned as I did not use a new one with every oil change.
Shaney
12-16-2014 03:19 AM
s2kbtos
03-14-2013 10:39 PM
AlabamaS2000fan
08-25-2008 11:25 AM
Seks
10-23-2004 04:17 PM
