CR toneaus and headrest diagrams from Honda
2009 S2000 - Interior Trim Removal/Installation - Rear Tray Area (CR model)
Special Tools Required
· KTC trim tool set SOJATP2014*
*Available through the Honda Tool and Equipment Program; call 888-424-6857
CR Model
NOTE:
· Put on gloves to protect your hands.
· Use the appropriate tool from the KTC trim tool set to avoid damage when removing components.
1. Remove the rear cover in numbered sequence.
2. If necessary, remove the rear cover bracket and the rear cover retainers.
3. Install the rear cover in the reverse order of removal, and note these items:
· If the clips are damaged or stress-whitened, replace them with new ones.
· Apply medium strength liquid thread lock to the anchor bolts before reinstallation.
· Before installing the anchor bolts, make sure there are no twists or kinks in the seat belt.
· Push the clips into place securely.
The attachments are from Honda dirreclty
CR Model
NOTE:
megan ap1
01-30-2013 11:02 PM
