Cr intake fit in an ap1
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
will the cr stock intake fit into a ap1 with no problems im sure it will it seems like it. Just want some feed back before I buy it off this guy.
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
It should fit, but there are some minor differences. The part number is different between the non-DBW and the DBW cars.
But why do you want the CR stock intake? It is no different that a non-CR intake. The part number is the same between CR & base.
![hello.gif](https://www.s2ki.com/forums/images/smilies/hello.gif)
Meh...it *should* fit. But it probably won't be identical. The intakes from 00-05 are all perfectly interchangeable. But the 06+ cars have a different part number...so there is a difference. What it is, I can't say...it might be something like a missing bracket, etc.
Either test fit, or try to find another 00-05 intake if you need a stock one.
I want to say that the only difference is a hole on the elbow that connects the box to the throttle body. There is an air temp sensor that I believe is not there on the previous years.
Joaquin
Joaquin
