CR Alignment Settings?
Does anyone have the full settings for camber/castor/toe for a factory CR?
so far in my search on S2Ki, i've found the following 2 comments
Does anyone know for sure?
thanks in advance
The CR alignment looks like it should wear the tires out slower than the regular AP2 or AP1 alignment. IIRC, the CR specs only 5.4mm of toe in for the rear vs. the 6mm for stock AP1/2.
I believe the CR is -.7 camber in the front and -1.8 in the rear. This should be with you in the car, of course. Good luck.
thanks in advance
Originally Posted by negcamber,Jul 15 2009, 04:20 PM
Search worked for me...hit it in the first thread from "CR AND Alignment".
Only difference is rear toe:
CR model: 5.5+/- 2mm. (0.22+/-0.08 in.)
but i know what to do for next time
turbo8765
07-19-2011 03:51 PM
