Couple questions
Couple questions
Hey everyone I just got my car back from the shop and the abs light is on the guy at the shop told me this Is from being lowered which I thought was complete bs. Also I noticed my car has a bad vibration when I accelerate but I think tht night be because I need an alignment you think that could be the reason?
That was I thought causes there aren't any abs sensors in the suspension but my work was done at porter chevy cause that's where I have a warranty and bought the car
Your bad vibration on acceleration is likely the typical inner CV joints being pitted (unless you've got a severely deflated tire). You need to do the CV joint left/right swap or get replacement 1/2 shafts. There is some controversy over this but it's possible that they got pitted because the car is lowered. Try installing 1/2 shaft spacers. You light luck out and this could fix the problem even though it may only be temporary. Get the split 1/2 shaft spacers. This will be a lot less work than changing the CV joints around and a lot cheaper than buying 1/2 shafts.
Whoops my bad I misread it but the shop just did a motor swap all the air in the tires is good but I think a wheel weight fell off cause my one rim doesn't have one anymore so I'm guessing that's the problem with the vibration but I don't see how them doing a swap caused the engine light o come on
jyeung528
32
06-03-2009 03:28 PM
Kekoa
03-29-2007 04:45 PM
