Could anyone help me with DIY brake fluid change??
#21
[QUOTE]Originally posted by Ludedude
The cap on the brake fluid reservoir under the hood of my S2000 clearly states that you should use DOT-3 or DOT-4 fluid.
#22
Administrator
Well, since Honda says either DOT-3 or DOT-4 is OK then I don't see an issue. I wouldn't mix them but I have no qualms about running either of the recommended fluid types.
Honda makes a DOT4 brake fluid btw, and they also claim it's safe to use in DOT3 or DOT4 braking systems.
Again, under the hood of my Honda it's clearly labeled that I can use either DOT3 or DOT4 without prejudice.
#28
Administrator
[QUOTE]Originally posted by AquilaEagle
I've got some Motul RBF 600 to put in mine, hopefully getting it done tomorrow, as I am supplying my own fluid - how much is needed to bleed then fill back up?
#30
I believe that the writing on the brake fluid reservoir is STANDARDIZED across all makes - I checked 3 different makes and they read the same. 3 and 4 may be compatible, but that does not mean they are preferred by Honda - that is why I believe there is confusion on this point.
