Cost of synchro replacement
Hello everyone. I just wanted to know around how much does it cost to have synchros changed. I need to have my 2nd gear synchro replaced for my 00 s2k. thanks for everyones help.
You're talking $500+ in parts, list, and at minimum of 8 hrs of labor. That's assuming the bearings and everything else are in good shape. I would expect a dealer to charge around $1300 for this.
It would be cheaper to swap in a used transmission. Maybe 6-8 hours of work and less than the parts cost for the trans.
Get a used AP2 trans off the boards here, and you wont regret it!
Originally Posted by supahman04,Jan 5 2010, 06:46 AM
I thought AP1's werent supposed to use an AP2 tranny beacuse of the difference in gearing?
Personally, I'd prefer the AP1 tranny's closer 4-6 ratios in either.
But for a street-only car, the AP2 trans is probably a better all-around compromise (slightly better off-the-line acceleration, very slightly lower cruise rpm in 6th).
