Cooling system issue
Originally Posted by Slows2k,Aug 8 2005, 12:02 AM
Did you follow AEBS instructions of torquing the studs in the block 1st to 10ft/lbs?
You will have to remove the Cams and rocker shafts/stands to retorque the nuts.
Originally Posted by xviper,Aug 8 2005, 09:05 AM
This may be very incidental compared to the suggestions already posted. How tight is the hose connection between the rad filler neck and the reservoir. If it's loose, it will convey fluid to the reservoir as the coolant expands but will not pull back in when the engine cools down. I've gotten into a habit of putting small hose clamps at the rad cap end and at least checking the end where it connects to the overflow tank.
I will put a clamp.
I would be willing to bet the headgasket is blown. Retightening after it is blown will not accomplish anything. 12 lbs is a very high boost and 3-1/2 inch pulley is very small to the point of exceeding max impeller speed.
I wouldn't try retorquing the bolts after the gasket is blown. I know ARP often reccomends retorquing after 1 heat cycle, but AEBS doesn't.
Exceding max impeller speed? Have you looked into a T-trim?
Na, won't bother w/ sc's after this one, i've looked into the ball bearing trims instead
There is still the lack of torque even at 11-12psi.
Then again, why didnt i buy a v8?
This is my version, obviously a lot different than yours. Forget what I said to you before. What happened was I called them up to ask them about these instructions and they said to follow up to the stud preload to 10ft/lbs and then the rest to follow Honda's torque instructions, so obviously the "loosen and retighten to 22ft/lbs" step was missed
riceball777
10-26-2011 11:53 AM
