Coolant temp range...
Old 10-29-2013, 07:20 PM
AP1Driver's Avatar
Default Coolant temp range...
Hello all,
Just curious if 206 F is the normal temp for the fan to kick on on an 01 S? My scanguage shows that the temp fluctuates between 188 degress and 195 degrees regularly, and climbs to 206 at still idle for extended periods before the fan comes on...
Normal?
Old 10-29-2013, 07:52 PM
Mister Jew's Avatar
That is fine.. My 02 fans come on I believe at 204f. Most cars operate at idle over 200f as long as your at 3 bars max your fine.
Old 10-31-2013, 05:28 PM
AP1Driver's Avatar
Thx man. I'm not used to having the scangauge connected in my S so I never had an exact readout before, good to know...
Old 11-02-2013, 06:48 PM
Utah S2K's Avatar
For a 2001 S the fan switch set point is 196 to 203 degrees F.
Utah
Ref: '00/''01 Helm Manual page 10-20
Old 11-02-2013, 10:06 PM
AP1Driver's Avatar
Mine kicks on at 206-207...? Maybe my scan gauge is off a few degrees ...
Old 11-06-2013, 04:11 PM
Utah S2K's Avatar
Don't know. The Helm Manual (aka Honda Service Manual) is a few clicks lower...........For an AP1
Utah
Old 11-06-2013, 04:13 PM
s2000maniac's Avatar
My ap1 kicks in at 204-212F
Old 11-12-2013, 06:28 AM
modifry's Avatar
Understand that the scan tool (and ECU) are reading the temperature from the ECT sensor at the back of the intake manifold. The fans are controlled by a separate switch mounted in the bottom of the radiator. It's pretty much guaranteed that the coolant in the intake manifold is hotter than what's at the bottom of the radiator.
Old 11-12-2013, 12:39 PM
AP1Driver's Avatar
Thanks for the clarification modifry much appreciated .
Old 11-13-2013, 08:39 AM
lopez14's Avatar
My 00ap1 fans come on at 206f. Readout via Autometer water temp gauge, with the sensor in my upper radiator hose.
Quick Reply: Coolant temp range...
