Coolant in oil
Anyone who uses UOA's as a tool for diagnosing contamination problems needs to either send a clean sample in for a VOA along with your UOA sample, or afterwards to see if there actually is a problem.
Also, many oil companies use sodium in there additive package at fairly high levels. That's why I don't use these oils anymore. They're just to distracting if you do oil analysis.
While the compression test is a good idea for future baseline and to get a good picture into health of your engine, like was mentioned those amounts are way too low to be a HG or issue with head itself.
So do the compression test, but don't think of it as part of diagnosing the elevated levels from the analysis.
I am glad to hear that the low levels are too low to be a bad HG. I really did not want to have to tear my head off right now. way to much to do haha.
I did check the Intake manifold gasket and it is a black one, so most likely stock.
I Since I bought the compression / leak down tools, I will do them any just to get a good baseline of my engine.
I think I will just start with a coolant flush and re-fil and go from there.
Once again. Thanks to all the answers. Truly appreciated.
![happy.gif](https://www.s2ki.com/forums/images/smilies/happy.gif)
